2004 Fuel Lines
My rear metal fuel lines from the nylon lines at the fuel tank to the quick disconnects at the base of the tranny/engine need to be replaced.
All the aftermarket kits I have seen don't have the quick disconnects they are threaded, so I would have to replace from the TB back to the
tank. Does anybody know where I can just get the rear lines? I could buy the whole OEM and just use the rears, but that is up around the
$300 range. It's getting getting colder and no garage at my disposal is the problem. Any ideas.
'04 Silverado
Mike
Rear lines are you talking the nylons from the sender that connect to the steels? The nylons from the tank are sold separate from the steel lines from GM. Got any more specs on the truck? Engine, cab, etc?
2004 5.3L 4X4 auto. The line I'm referring to are after the nylon lines from the tank, which are metal and run along the frame to a braided metal line that goes to a solid metal line to the TB. I'm looking for item 5.
'04 Sileravdo
Mike
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
