Heater issue
04 Silverado, heater blowing cold air. Coolant is slightly low, temp gauge showing 210 steady. No visible leaks or overheating. Was going to replace thermostat but thinking that if it was bad the temp would not be normal?
Will coolant level a couple inches low cause it? (Assuming not, but haven't yet added)
Any opinions?
Low level or air pockets can cause an issue. Try adding until at correct level. Or flush the heater core
