Regular Cab Stereo Systems
This setup will not work for everyone. You must be very short or something.
Because I couldn't fit that. Also just a suggestion depending on the size of each chamber, you.might be better off with sundown sd3 in that box. The sa series is not for sealed applications
Talked to Sean before I ordered them and he said I could run them in a sealed box although the sd3 would sound better but it gets the job done for me
what box is that? I know Subthump sells a box but it's really thin. I'm short so I could fit something a little bigger behind me.
Had a local guy build the box for me
Any way you could post up some dimensions of the box? I'd love to be able to run some 12's in my trucks.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Alright I got a question, I got a line out converter that feeds the rcas to my sub amp and now I'm wanting to add an amp for my door speakers. How would I wire that up? Would I need something like a Lc2i to feed the bass outputs to my sub amp and the high rca to my voice amp?
An LC2i will do the job. Just curious what expectation of quality do you have?
For $80 the LC2i will get the job done, however I did a little searching and found a sweet deal on a DQ61 -> https://www.walmart.com/ip/AudioControl-DQ-61-Black-Digital-Signal-Processor-w-EQ-and-Time-Delay-Black/104461177?wmlspartner=wlpa&selectedSellerId=149&adid=22222222227046814931&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=146920613975&wl4=pla-255790067660&wl5=9032261&wl6=&wl7=&wl8=&wl9=pla&wl10=108214235&wl11=online&wl12=104461177&wl13=&veh=sem
I went with an Audison Bit Ten in my truck as it de-equalizes the input signal and allows me to adjust on a 32 band EQ. Love the bit ten.
Several ways you could do that..get a 4 channel LOC, use Y cables from the LOC you have or get a speaker amp that has a through output (run the LOC to the new amp and connect the through output to the sub amp)
Sweet thanks, maybe if I had upgraded speakers all around I'd go for something like that but I just have 2 door speakers lol
I was think of that y cables but didn't know if it would be recommended or not lol
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
