Vibration Sound
I am getting this same rattling sound when I am stopping 5mph to stop then from a stop when first accelerating. I thought is was my Corsa exhaust and the dealer said it was the fles fitting on the head pipe. Corsa sent me a new pipe but the noise is still there. I next turned off the truck then stopped andf noise is still there so I think I ruled out the exhaust or heat shield. I am guessing brake issue. Dealer has it and hears it but can't figure it out.
To determine my issue, a tech crawled under the truck and had me repeat revving it (while in park) to see where the noise was coming from. If it wasn't for that I'd still be trying to figure out what my issue was!
Mine was determined to be the wheel balancing glass beads in the tires hitting the inside of the rim as it stops.
