HELP WITH LED LIGHTS!
Hi guys, I recently installed two led pods on my back rack. I used a fused/relayed/switched wiring harness I got of amazon, and i have used this one before on other trucks. For power I used a fuse tap into the 30 amp sunroof fuse, because i have no sunroof. Everything worked great untill I noticed my lights on outside. They wernt fully bright, and the switch in the cab was off. So now when I turn them off the slowly shut off, then come on to about half brightness, then turn off eventually. Its like power is somehow bleeding through??
*I have checked my ground, replaced the switch, and checked all connections.
Were the pods 12 Volts or 9-36 Volts? Does the harness include a capacitor for noise and spike cancellation?
I believe the sunroof feed is a rap power source, hence your problems
