2016 6.2l engine mods
I was wondering if anyone has changed there throttle body and was wondering if you had problems after. Also I was wondering if anyone has took out the 3 cat before the muffler and was there any codes reading on any of 2 two I am asking about I'm new to this new stuff so any help would be nicepost-152701-148244371969_thumb.jpgpost-152701-148244378931_thumb.jpgpost-152701-148244380683_thumb.jpg
Sent from my SM-G930W8 using Tapatalk
I changed to a ported TB on my Camaro. No issues whatsoever
Ryan
Unless you are going with an OEM ported TB there is no real gains on messing with the TB. The 6.2 trucks use the same size TB as the Corvette and Camaro with the same engine. The 3rd cat is not monitored, it is only there because California requires them as part of their C.A.R.B. act. GM only makes 1 vehicle that is 50 state compliant now so all of the trucks all have the 3rd cat now. It is fine to cut the 3rd cat out provided you fully weld back in a piece of straight pipe.
Would this mean that the 3rd cat on the 5.3 is ok to remove too?
    tblt44
    tblt44
  • Who's Online   2 Members, 0 Anonymous, 411 Guests (See full list)
