Unistrut in 2016 Sierra
I tested out some 1 5/8 Unistrut mounted in my 3500hd. These are test 41" long pieces I already had. Testing them out with som Nissan Titan parts I kept from trading in (bed extender and tie downs). Next I will mount some long rails the full length of the bed. Its not really to extend my 8'bed but to corral cargo at the back and reuse parts I kept. I used the movable tie downs I got with the truck and so 50mm long 8mm 1.25 full threaded bolts and some 3/8 1.25 dia fender washers and the coated 1 5/8" x 1 5/8" Unistrut. I cut the unistrut with a porta band metal band saw and beveled the cut on a 12" disc sander.
I will get a youtube video of it up this week.
When I saw the topic name I was thinking it was about the front suspension or something. I never thought of the industrial stuff. I used a bit of it during my working days. Good idea & probably cheaper than an aftermarket set up. Does the galvanized coating stand up to inclement weather?
I just put a Revolver x2 cover over my bed so mine will last a long time. They sell an aluminum one too. When i extend the full bed length I will tool dip the cut as well. I also need to mill up some new brackets for the bed extender and narrow it a bit for the tonneau's rails. May add a headache rack so i need to make sure i keep.those brackets in mind too.
This is 10/10. I've been trying to figure out a way to mount my ax in the bed without drilling a ton of holes. This could work great for that.
Sent from my SM-G920V using Tapatalk
What are the clamps pieces you are using in the Uni strut? great idea.
Just remove the tie-down eyebolt and slip in a 5/16 washer that is 1.25" dia OD into the unistrut and run a 8mm 1.25 by 50mm long bolt into that washer, through the unistrut and the plate that was behind eyebolt and tighten it down.
I made two videos on this. I have quite a few videos of stuff I do in my personal makerspace I call the Mikiespace lol. I have built a few DIY CNC machines - 5 or six routers, retrofitted a 1050 knee mill, and am working on a 1236 CNC metal lathe all to do routing, milling, turning of many materials including wood, plastics, aluminum, steel etc. I also built a 3d printer (Ordbot( and have many manual metal tools and a full cabinet shops worth of woodworking tools. Lets just say I have a lot of fun doing this kind of stuff.
Anyway here are the unistrut videos if you care to watch them.
Also for those folks unfamiliar with unistrut here is a link to mcmastercarr for their strut. They sell a bunch of parts for it but they are pricey.
https://www.mcmaster.com/#strut-channel-systems/=15qhzka
Also shop home depot and lowes for some parts or Menards if you have one.
Also know 1/2 bolts nuts lock and flat washers also work but you need to get a wrench in behind them to hold stuff down.
The unistrut spring and flange nuts also come in 1/4-20 and 3/8-16 in addition to the usual 1/2-12.
It truely is an erector set.
I use a metal bandsaw to cut my strut. Abrasive saw or grinder would also work but will give off a ton of sparks so be careful.
Would Graingers or a similar industrial supply outfit carry Unistrut?
Yes. Fasenal, and most HVAC and Electrical supply houses do as well.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
