ACC on / ACC off - Same as Retained Accessory Power (RAP)?
pgamboa
As the title says, I am curious if an ACC On/ACC off signal is essentially a switched 12V signal?
Needing to find a source in the driver side door panel. Based on the schematics, I don't see one present.
If so, I guess I need to run a wire from the left side fuse panel to the door. Hoping I can use an unoccupied pin slot in the X500 door jamb connector to avoid fishing wire through.
What are you trying to wire? An REM to an amp?
I've got an aftermarket mirror fold module. It is wired up now and is working. It will currently fold/unfold the mirrors when the door lock actuators open/close.
This is what it says for the ACC On/Off Signal.
"If ACC on, the system shall be disabled automatically to ensure driving safety. Only the original side mirror switch can fold or unfold the side mirror".
So... when I unlock with the FOB, mirrors unfold. I get in the truck, shot the door and start the truck. When I shift into gear, the doors lock, mirrors fold in. It is not disabled because the ACC On/Off signal is not connected.
Maybe I'm over complicating it in my head. But I have a amp installed and for the REM I researched how I can turn it off when the vehicle is off. For this I found an un-used pin under the dash, in the fuse/relay box. Stays on until the ignition is turned completely off AND the driver's door is opened.
The module is behind the driver's door panel. I was hoping to have a circuit somewhere behind there so I don't have to run a wire to the door and through the boot in the door jam.
    tblt44
    tblt44
  • Who's Online   4 Members, 0 Anonymous, 709 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
