I have a 2013 Silverado 2500HD LTZ and I received a nav update dvd for christmas but don't know how to eject the old one to insert the new one
HELP
MENU > NAV > Map Database Information > Change
the entire screen swings open ...
When I do (MENU > NAV > Map Database Information > Change), I don't have the "Change" option
you might have to put on the parking/emergency brake or be stepping on the brake pedal, and in park (to make sure you aren't doing it while driving)?
I had already tried that, didn't help
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
