Silverado suspension
Tjs618
Whats up I have a 2014 Chevy Silverado with a 2.5 in leveling kit and I took the blocks out of the rear. I love the height and the way the truck sits but I wish it would handle a little better when I take it off road ( on the beach). Does anyone have any preference on shocks and struts?
Thank you
Get some Fox Shocks. Buy leveling shocks and throw the front spacers away. Consider buying some aftermarket upper control arms if you drive off-road often.
Thanks for the input! Do you know where I can get good upper control arms at a affordable price?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
