2014 CarPlay?
Is there any way to add CarPlay on to my Intellilink without spending a ton of money or getting a new unit?
FYI - Its a 2014 Z71
Just buy a 2016 or newer set up. Not worth it but you can do it.
Wow, why didnt i think of that? So smart.
Your the one that asked. Now you know. :dunno:
It's you're*. If you read the question, it stated "without spending a ton or getting a new unit."
Way to get your two cents in, you keyboard tough guy.
I would not consider a simple $1500 OEM mod a ton of money.
$1500 for Apple CarPlay would be considered a ton of money in most circles.
had the android auto added to my 2016 sierra when it was in for its first service since it wasn't added on assembly and not really impressed,infact it altered my pandora app.before when pandora was activated i could see the album cover on the screen now that went away. also found that in other vehicles when a flash drive was used the album cover was also displayed but not with the intellink system.
