4x4 trouble
02 Silverado. When selecting 4wd on push button, light flashes couple times then goes solid as it should, but I hear nothing under truck moving and have no 4wd
Need to try, that will help pinpoint the issue
Sent from my SM-G530T using Tapatalk
Do you use it a lot?
4HI that is.
Is there two different ones. 1 on transfercase and one on front diff .?
I'm not 100% sure because I don't have a truck that year model but you should have an actuator on the differential and a shift motor on the transfer case. There is also a position sensor/encoder that can go bad and cause issues.
