Cooper STT Pro or Nitto Ridge Grapplers ?
BowHunter1
Ok fellows, its time to finally get a new pair of shoes. I have over 45K on my current Cooper ATP's and they have held up Great! They were my first set of Coopers and I have been more than pleased with them thus far. They still have a good amount of life but my cousin is looking for a set of hunting tires for next year and is willing to take them off my hands before they are shot. For a reasonable family price of course :)
I will also be changing tire sizes which is how I narrowed it down to these two tires. Current size is 275/65 20 and plan to go to 295/60 20 which is about the same height but wider of course. I do have a 2 1/2 inch level in the front with rear blocks so I'm hoping I can make these work with minimum issues.
Looking for opinions on either of these two tires and possible tire size before I purchase. FYI the ridge grapplers are about $25 more a tire and I will be purchasing from discount tire most likely since they have treated me very well in the past.
Thanks in advance and happy trucking!
Well, I guess it depends what is more important to you. The Coopers will be better in the mud, but will probably be louder on the highway and may not last as long. The Nitto's will be smoother and quieter, but will not do as well in muddy conditions.
I just put the nitto ridge grapplers on my truck in that exact size and love them!! They drive great on the road with just enough "meat" on them to get you through mud. They look better then your average all-terrain and perform good so far. Not sure how long they will last, I probably have 500 miles on them now. 89084366787c62b3a5263e9f5e3012f4.jpg28b50e955f2cf05a4aef0c6484b15c7b.jpg554acd13687b1a0a2b0031b9d88ec2e0.jpg767a5cd8c49b9f552e963b53ba6545f7.jpg
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 290 Guests (See full list)
