I have a 98 s-10 4x4 I like the stance the zr2 has. Does anyone know what I need to do to upgrade my suspension. I not looking to make a mud truck or anything i just want it to sit higher.
2 inch body lift a good t-bar crank and i put air shocks on the back. I set about an inch higher than a ZR2.
I have the flares too.
From the factory,a ZR2 sits 3" taller and 3.9" wider than a standard 4wd S10.With a 3" body lift,you'd be able to get 31's on your ride or you can look into the 5" Trailmaster and probably work 32's.
I wouldn't reccomend any larger tires with the Trailmaster because S10's have poorly designed wheel wells and are prone to rubbing.
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 1,050 Guests (See full list)
