GM Weathertech style mats?
js4506
thanks for all the input! Ended up getting husky x-act contour for the front and then the weathertech full coverage rear in the matching brown color
Well I'm a little late but there are 3 or 4 threads on here talking about the new GM liners. These are different from the Z71 and All-Terrain mats. Here is the main thread:
http://www.gm-trucks.com/forums/topic/184854-new-gmc-floor-mats-2016-these-are-real-nice/page-1?hl=liners
Another one with good info:
http://www.gm-trucks.com/forums/topic/195331-all-weather-floor-liner/?hl=liners
    Gkistler
    Gkistler
  • Who's Online   3 Members, 0 Anonymous, 881 Guests (See full list)
