2008 Silverado LTZ Z71
berteras
2008 Chevy Silverado 1500 LTZ Z71 4WD for sale, asking (((((($21,600 obo))))))). 106k miles. Truck has been my daily driver for the last 6 years, I'm the 2nd owner. Truck is in great shape inside and out. Interior still looks new, paint is in great shape, no mechanical problems. I've purchased another truck and don't want to keep both so I've decided to put this one up for sale. Transfer case was replaced in June of 2015 and has 18 months of warranty left. Ball joints, control arms and cv axles changed last summer. All work performed by certified mechanics, receipts available. Struts and shocks all changed last weekend. Truck has never been used off road. I have plenty of pics available, just ask!
LTZ package, truck has everything but Navigation and backup cam. Truck has sunroof, rear entertainment center with roof mounted TV and dvd player. Heated front seats, black leather interior. Magnaflow exhaust, Volant cold air intake. Spray in bed liner. Ddm tuning HID kits in low beam and fog lights. Go Rhino Dominator 2 side steps. All emblems removed from truck. Truck has never been used for any sort of heavy towing, only thing pulled behind the truck were a few boats. All maintenance has always been done on time, oil has been changed every 5k miles. Transfer case fluid changed every 10k miles. Front diff fluid just changed, all full synthetic fluids always used. Truck runs and drives great! Title in hand. Contact me at [email protected] or 504-338-7077. No calls after 10pm please!!
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
