2017 Sierra Led headlights blotch?
I have a 2017 Sierra SLT which has the full LED Headlights. Towards the left lane, there appears to be a blotch in the beam pattern. I had the dealer take a look at it and they told me that the tech couldn't find anything wrong with it. They said it is most likely designed like this to prevent blinding oncoming traffic. Seems odd as I highly doubt the extra 2 few feet of beam pattern would make a difference.
This is an uphill shot. The area I'm referring to is above the red arrow. When driving on flat ground, the botch is bigger, takes up about 4 feet of road space and is more noticeable. Is everyone else's like this who has the full LED headlights? Also when the high beams are on, there is an even bigger botch that takes up a lot more area but it is not as dominant as when the low beams are on. It just seems odd as it seems like only the left headlight has this issue. post-68685-0-50330100-1488340740_thumb.jpg
I have noticed this on my 2016 I just figured it was on the left side for oncoming traffic. When I pull into the garage the lights come on and you can see the pattern with the indentation
Looks like a typical cutoff line. After I put in my FXR projectors and HID lights it's quite clear to see. Then I all of a sudden was able to notice something similar on my wife's volkswagen with normal halogen reflector headlights.
Edit: sorry for a crappy picture but if you zoom in you can see what I am talkingredients about.
my 2017 has the same thing. I thought it was messed up as well but it seems that this is by design.
  • 3 weeks later...
    Afennell19
    Afennell19
  • Who's Online   3 Members, 0 Anonymous, 871 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
