2014 silverado
Where is the fuse for the front 12 volt plug in located, i have no power to the plug, the onwers manual and neither of the panel covers make sense
this is from a different post, maybe what you are looking for? at least for the location of the fuse it might help.
The source of power for the APOs
on the center stack can be changed
from direct battery power to RAP by
moving the fuse at location 10, in
the left instrument panel fuse block,
to position 11. Once the fuse is
moved, the APOs will continues to
work for up to 10 minutes or until
the driver door is opened. See
Instrument Panel Fuse Block (Left)
on page 10-49 or Instrument Panel
Fuse Block (Right) on page 10-52.
If you are not comfortable
performing this change, see
your dealer.
here is the whole instruction.
Accessory Power Outlets (APOs)
The vehicle may have APOs in
several locations. See Power
Outlets on page 5-6.
The APOs in the console or center
seat position are powered by RAP (Retained Accessory Power).
They will continue to work for up to
10 minutes after the key is turned
from ON/RUN to LOCK/OFF, or until
The APOs on the center stack come
from the factory powered directly
from the vehicle battery, and supply
accessory power at all times,
regardless of ignition key position.
If electronic items are left plugged
into these APOs for long periods of
time with the vehicle off, the vehicle
battery could be drained. The
vehicle may not start if the battery is
allowed to drain for an extended
period of time.
your dealer.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
