Sealed Beam conversion kit
Hey everyone, I have a 1998 Cheyenne K1500 with the sealed beam headlights. What are some places to find conversion kits to use modern bulbs?
summit racing, ebay...
search sealed beam conversion.
it is endless.
I chose ebay for my 96.. I have the skinny 9005/6 lights.
someone made a projector lens, covnerted to h1 (all metal) and then I added LED.
all kinds of things for sealed beam in the hot rod world.
Not expensive.
Yeah, I've looked around a bit and most things I've found were cheaply made and didn't work well according to the reviews.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
