"Chrome" bumpers
Hi guys
Are our front and rear bumpers actually chrome/chrome plated or are they stainless steel or some other material? I know we always say they are chrome because they look like it, but I was wondering if anyone knew if they were actually plated in chrome. I have some superficial scuffs on my rear bumper (cant even feel them with your nail) and I know getting anything out of chrome is a pain in the d**k.
Thanks!
They are not hashed, just some minor surface scratches. You can't feel them with your nail even, just make the finish look dull in certain light
Chrome, but poor quality chrome
one winter and there is surface rust creeping around edge on my front.......... :(
Isn't it chrome overlay or chrome plated?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
