body colored door handles
Thinking about ditching the chrome handles and moldings on my 2016 custom sport 2500. Does GM make pre-painted ones? My truck is summit white.
Does gm make pre painted ones that I can buy through the parts department? I checked gmpartsdirect but came up empty. I'm finding every color but Summit white on eBay.
GM are paint to match. I'd find someone to trade with.
Yes GM dealers have them. I couldn't find the part numbers but the parts department can get them. They used to run around $160 for all 4 if you have a crew cab. All the ones from 2014-2017 1500 and 2015-2017 2500/3500 are the same style. They come with instructions on how to change them out. It only takes about 15 minutes and you don't have to remove any door panels.
Not pre painted. Chrome is the kit they sell. Painted are sold primered and only individually. Same with the textured black. OP has chrome and is looking to ditch them for painted.
The above sets are pretty pricey compared to other colors
Agreed. Pricey in general. Bought my set of white handles and mirror caps for a 1500 for $50 shipped off Craigslist.
Gmpartsdirect has the handles, ready to paint for $21.00 each, I might just go that route. I'm sure I can get them painted for less than $200.00. Thanks for you help. I was able to find the body side molding pre-painted in my color from GM. I wonder why they do the molding but not the handles.
Okay GM must have changed it. In Dec 2015 I ordered my Rainforest Green handles directly through my dealer when I bought my truck. I was there a few days later when the Parts Manager opened the packages (I made him inspect them before I would take them :lol: ) and they came pre-painted.
OP -- like others have said your best bet may be to buy a set from somebody on here (or ebay). There are usually people looking for chrome ones so you may be able to swap for not much money. Even though you can get the primed ones for $21 each until you pay to have them painted it will get pricey!
Gas
23444119 and 23444120 are the upper in black, 23444125 and 23444126 are the gas lowers. If for some reason you have the temp sensor in your passenger mirror, the lower is 23444124 but, if they are factory installed they most likely will not have the sensor in the mirror.
Honestly I would not be the least bit surprised that those may have came off of a truck that someone wanted chrome handles on instead of the colored ones and they sold you the takeoffs.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,186 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
