Lund Step Rails
:smash: I recently installed a 3" lift on my 00' Sierra. I realized that I needed step rails for easier entrance into the truck and also to get rid of the visibility of the frame that stuck out like a sore thumb. I knew that most nerf bars installed directly to the frame, and those types would not help cover the expose frame. I then found some step rails from Lund that mount onto the body. Was a little skeptical at first, but they are awesome. Look great and are very sturdy. :fume:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
