Gas Pedal Squeaking?
Any of you have an issue with your gas pedal squeaking? Just recently started happening (under 45,000 km on my truck). I notice it mostly when I have accelerated and take my foot off the gas pedal. Sounds like plastic rubbing on plastic.
I have an appointment at the dealership next week Monday to have this looked at, but was wondering if anyone might have any ideas?
Thanks.
A little spray-on white grease or WD-40?
Really? You think that's all it is? Just seems odd that under 50,000 km it starts to squeak. Hate to go out of warranty and find out it's a bigger issue when it's too late.
Well, it's certainly worth a "shot" before you have to take it somewhere for service.
Fair enough. I'm picking up my new running boards and having them installed at the same time conveniently enough, so it's not out of my way.
Thanks for the suggestion!
I have had my gas pedal replaced 3 times because of this. There is nothing to lubricate down there and make it go away so they have been replacing it. Stupid design if you ask me. Its just plastic rubbing on plastic. My concern, over time, is will it start to stick if I don't keep getting it replaced?
If it rubs, it can be lubricated.
Try it dry sometimes; you'll see.
Go look at your "gas pedal" next time you get in your truck. The gas pedal is more of an electronic sensor. Actually they call it a throttle position sensor. I'd definitely be worried about spraying a liquid lubricant in there for fear of messing up the electronics. This is why I mentioned it to the dealer and they seem to agree with me since they didn't lubricate it but replaced it instead (3 different times @ 2 different dealers).
Silicone lube worked well on electro-mechanical assemblies in the military aircraft I worked on..Maybe it's different with GM stuff.
Just got back from the dealership on this. Even the service advisor said they ordered a new pedal for me and didn't spray it with any kind of lubricant as they didn't want to mess up the electronics on the pedal. Hopefully the new pedal is better next week!
Good! Unfortunately, my squeak returns between oil changes. Hopefully you have some better luck.
Fingers crossed!
Mine made a squeaking noise during my first winter of ownership (bought in the summer) that was brought on IMO from the plastic shrinking/expanding due to temp differences. Dealership fixed mine by taking putting in some foam tape in the assembly and haven't had a problem with it since.
I occasionally get gas pedal creak (not really a squeak) in my 2009 Impala with 115k on it. It does not bother me too much, but as already mentioned the solution is to apply a small amount of synthetic grease to the right area.
In the past I had a very annoying squeak from my Mazda clutch pedal bushings and finally I got rid of it by spraying WD-40 into the bushings. I usually had to reapply WD-40 every 30k miles or so as squeaking would return.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
