rear squeak, scrub
RP53
tried searching couldn't find anything
my 2014 Z71 47,000 miles has developed what kinda sounds like the break pads need to be replaced or something is scrubbing. i checked the pads and they are good, this sound is very strange, it only happens when going through a left hand curve and not all the time i does it intermittently, sometimes if you applying the brakes it does it sometimes not, sometimes if you aren't applying brakes it does it as well.
crawled under and i cant find anything that appears to be scraping, nothing lose, that i can feel. the sound is coming from the drivers side rear. am at a loss. has anyone ever experienced something like this
Rear leafs shifting horizontally in the turn, groaning due to dirt/dust in the shackles or derlin rub pads? The rear leafs are known to be noisy.
i really dont think that is the probblem. but it could be. taking it to the shop in the morning
