Check this out:
Wingnut
Mine too....But maybe thats because we would put on all of our football gear, and race them down the steepest hills we could find....Maybe.
My Radio Flyers had built in rev-limiters....If you went over 20, the wheels fell off. :D ?
It's a good thing GM didn't follow that model. :mad:
Big Wheels, and Green Machines suffered the same drawbacks. Of course there is nothing like a 3 wheel drift on a Big Wheel at 15mph :D:cheers: ....Yes, mom still has the videos.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
