Anyone know how to remove and replace these? Please tell me they can be removed without taking the bumper off. I am talking about the entire corner insert nt just the bottom tread.
Edited by PghJeff2
I took mine off but I already had the bumper off. I dont see how you could possibly do it without removing the entire bumper. There are like 5 or 6 screws holding them on.
Edited by Static
You can do it without removing the bumper but you need a wobble extension for your ratchet. I actually removed mine without removing the bumper to install some lights. I found instructions on the Anzo site where they sell replacement lighted steps (I didn't put those in but used the instructions to remove the step cavities):
http://www.anzousa.com/media/installation/e0da1a5a.pdf
Where do you find the screws behind the pocket? I see one that holds the slotted tab in but where is the other screw?
  • 2 years later...
6 hours ago, Gunnaman32 said:
Did you wind up having to take the bumper off?  I don’t see any other way to install these.  Frustrating.
the anzo instructions  show how to do it without removing the bumper.  the link from above doesn't work but i saved the pdf when it was on the anzo webpage - hoping i can attach the file....   looks like it worked!  hopefully it will help you out!
bumper step removal.pdf
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 495 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
