Stabilitrak & Brake Assist Warning light across screen today?
hou1ptt
Just took it to the car wash today, on the way home these two warnings came across screen.. Now my stabilitrak light is on the dash.. Any ideas what causes this? Thanks!
Yeah, I looked at them, they look fine.. After reading & doing some research, Im pretty sure it has to do with the Range I installed.. Its been on there for about a month or so, this is the first time I had any codes.. Idk..
I can't find the link / video, but there is a known issue with a bad ground where the drivers side A-Pillar and dash come together. A piece of insulation gets stuck between a wire and the ground point. If someone has the link, feel free to share. Simply have to remove the defroster section of your dash (not sure exactly how) and the nut and wire are right there. Unhook the wire, clear out the insulation to make a good ground and done.
Yep - the G218 ground. It's on the driver's side way up in front of the dash speaker. I don't have the link but if you search these forums for "G218" or "G210" it should come up (the G210 is the same thing on the passenger side).
  • 5 months later...
Did you check to see if this was the issue and did it work?
I have a range chip plugged in and have thrown the service “stabilitrak/service brake” code go off twice now and want to avoid the dealership if I can.
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   1 Member, 0 Anonymous, 733 Guests (See full list)
