Fog Light Bulb Replacement HELP!!!!
Alright guys, either I am an idiot, or this thing is just a POS. I can not for the life of me figure out how in the hell to remove the foglight bulbs. I ended up walking away because I was getting to the point where I was going to break something. Can anyone guide me in the right direction, before I lose my freaking mind?
Thank You!
I think I figured out what happened. I ended up braking off the 2 tabs that you are suppose to push in to release the bulb. So now I have to figure out how to depress the little locking mechanism to release the bulb.
That video is funny, if you watch carefully the guy can't lock his replacement bulb in place even after he clips the socket the bulb still isn't secure.biglaugh.gif It's the right idea though he's just not having any luck.
Yep - just squeeze the 2 sides together with your fingers and pull straight back.
It confused me since most GM bulb sockets are the "twist 1/4 turn" type. These aren't.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 839 Guests (See full list)
