RPMs jump up on highway at random
I've got a 2014 Silverado 5.3L and my issue is when I'm driving on the hugh way at 60mph with cruise control on and on flat road every now and again my RPMs will jump around 300 to 400 rpm then settle back down to about 1500rpm. Is this normal? Is this when it switches from V8 to V4? Or is it the torque lockup solenoid on the fritz?
Sounds like a tranny issue, either in the t/c or possibly a bad solenoid like you mention.
AFM does not cause a change in RPM. A jump that drastic has to be a trans issue.
My AFM when changing to V4 causes a slight increase in RPM. Nothing like the OP is mentioning though.
Make sure your cruise control works! Brake pedal switch controls cruise control, stop light, and a signal to the transmission control unit. Donot confirm it's operation solely by means of a brake light test, as it controls 3 switches signals.
If the data signal to the bus controler is sticking (brake pedal switch) the transmission will behave strangely and cruise control usually will not work while driving within the first 1-2 minutes of first drive of day. If cruise does not engauge properly, try lightly taping your brake pedal while cycling your cruise to set. If your cruise begins to work after lightly taping brake pedal, your stop switch is failing or damaged.
If all above works fine, suspect your torque converter or transmission being the culprit. A weak or failing solenoid can cause weird issues, but the Torque converter could have a hairline crack, known problem with some.
Best of luck
It's not AFM causes the change in RPM though. It's likely the Torque converter locking/unlocking.
So cruising down the interstate at 70 the TC is locking and unlocking? Every time mine switches to V4 on interstate there is a small fluctuation of RPM.
Think about it. The engine rpms aren't changing just because half the cylinders deactivate. It has to be something else. The TC constantly adjusts based on the terrain and load on the vehicle.
Mine does this all the time and drives me nuts. I have the same issues as the OP and definitely notice it when it changes from V4 to V8, and yes 300-500 RPM jump from switching both ways, from V8 to V4 and V4 to V8. I call it surging and actually posted about it a while ago.
Sorry I do not have an answer or solution, but I experience the exact same thing
It's your torque converter. My 2015 Denali did this. Granted mine had the 6.2 and 8 speed but what your explaining is the same. The converter would not lock and was slipping as it was trying to lock. I tryed everything and the dealer had truck more then I did so I traded the truck in.. good luck, hopefully if that is your problem they can fix it
  • 2 years later...
Did you get this issue figured out? I have a 2018 with the 6 speed and it’s doing the exact same thing. Thanks.
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,380 Guests (See full list)
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
