Wiper Motor Curcuit board Recall
This is from my new Consumer Reports (Aug 2003).
This refers to the cracked solder joints that many people have had causing erratic wiper problems.
The list is long but seems to include most pickups, Blazers and Astro type vans.
You are instructed to have the dealer replace the wiper circuit board and cover.
for info call: Chevy 800-222-1020
GMC 800-462-8782
Olds 800-442-6537
It's about time!
I know that my '94 GMC Sierra had a problem with the wiper motor. Every once in a while, nothing happened when you turned the wipers on. They started working if you gave them a little push though.
I have already had and fixed this same problem on my '94. I went up to the dealer just to check it out and they ran my vin and said that my truck was not recalled. :cheers:
