Anyone Using this Lowering Kit?
Hello, I saw this Kit On Ebay , Anyone used this kit ? It said in the description that it lowers a reg cab 2 1/2 Maybe I could Cut a little off that coil Like The Good Ole days! I already have a shackle on the back and took put the rear block, The Back is about 3 1/2 " lower Than Stock so it sits level.. I figured I can Move The Bolt in the Shackle in the back .. Thanks !
http://www.ebay.com/itm/Chevrolet-Silverado-GMC-Sierra-V6-3-6-Drop-Lowering-Kit-2014-up-SPRINGS-/332160632001?fits=Year%3A2017%7CModel%3ASilverado+1500&hash=item4d565104c1:g:YF8AAOSwrmdTrZhL&vxp=mtr
Don't use ebay junk and don't chop your springs. The rear shackles will only get you 2" of drop at their lowest setting. If you want to go any lower you can get 2" drop leaf springs in the rear, or do an axle flip and some shackle hangers.
For the fronts if you want to go lower, either buy an adjustable strut (mcgaughys) or a drop spindle or a combination of the two.
Any questions feel free to DM me!
2/3.5 will barely be noticeable but use good stuff.
Spindle in the front over a spring
