Window Visor Color Match
Has anyone done this? I'm sure someone has done it without taking them into a body shop.
Had a few questions on what you used and what I should stay away from.
I matched my ex wife's front bug guard a looong time ago...Trick is to get clear and paint them from the backside...
great suggestion!
Yeah I read about that, problem is I already have blacks ones and want to color match them.
Anyone else?
