Driver assist handle
Same pillar and part numbers. Do a search and you will find 3 or 4 threads already on here showing install pictures.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
