Over the past several months, I have been noticing upon startup that the dash has been display "Theft Attempted", now over the past 3 days, my alarm has been randomly going off as I walk away from the truck. Remote is in hand and is not being mashed so no chance of the panic button being it. Anyone have this happen to them? Pretty confused on whats going on here.
Edited by OKZ71
My alarm went off randomly when I reconnected the negative battery cable. Scared the crap out of me since my head was under the hood. No message about theft attempted though.
  • Haha 1
I've put a couple ground cables on for this concern. If you're mechanically inclined, you can perform a voltage drop test on it to verify otherwise, you'd be just throwing a part at it.
Found a that the negative battery terminal was loose, tightened that yet still is going off randomly.
Thanks for the tips though!
External interference from somewhere..
Interference from the remote or something on the truck?
  • 7 months later...
I have the same issue with my 2015 Yukon Denali. Been to 2 dealers who say they have never heard of the issue yet I have seen this problem in online forums over and over. I am frustrated because in fact this morning I was sitting in my home and the alarm randomly went off. I hit the unlock fob and it stops. It actually happened once when I visited the dealer and they offered no explanation or help. I wish someone could explain it. I'm close to getting rid of it
  • 2 years later...
My 2017 Silverado 2500 had a theft display on the dash earlier today. Approx 4 hours later the panic alarm is going off for no reason. Any ideas?
I’m having the same issue with my 2016 Sierra. The dash frequently displays “hood open” although firmly closed, as well as “theft attempted”. All Terrain... too many electronics for its own good. Time to go back to the basics.
Edited by Oatboat
Spelling error
  • 6 months later...
Similar issue just happened to me on my 2016 Chevy Silverado.   Keys with fob hanging on a hook in the house, undisturbed.  Truck parked in the driveway.  The Panic Alarm went off twice within 20 minutes.  The first time it seemed to 'time out' before I could get to the fob.   The second time, I hit the fob panic button to cancel, but that did not seem to work.   Hitting the Unlock button on the fob cancelled the Alarm.   No 'Theft Attempted' or other warnings displayed.
Welcome to the site.
May want to change the batteries in your fob. Coming up on 5 years old if you have not changed it.
40 minutes ago, Daedelus523 said:
Any update OP?
You might want to direct quote the original OP, or start a new thread. You are asking for a response from a 3 plus year old post.
Any details you can share about your truck would help too.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,188 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
