Another WAY O\T Question
General Lee 01
Whenever I'm out on the highway I see "Older" Gentlemen driving and they have a bumper sticker on the back of their car\truck that says "Semper FI" or something like that.
I assume it has to do with Military Veterans cause they usually also have a "Retired US Marine" sticker, etc too.
So I ask, what is Semper FI?
General you will find a ton of latin motto used in the military.
The one that I always like best is "De Oppresso Liber" (To Free The Oppressed", that is the motto of US Army Special Forces.
Sine Pari (without equal), Army Special Operations Command
Sua Sponte (of their own accord), Army Rangers
Lo Que Sea, Cuando Sea, Donde Sea (anything, anytime, anywhere), Army 7th Special Forces Group
Semper Paratus (always prepared), US Coast Guard
Defensor Fortis (defender of the force), USAF Security Forces/Force Protection or whatever they now call themselves
Audentes Fortuna Juvat (Fortune Favors the Bold) USAF 366th Wing
and there are hundreds more floating around in the military...
:D
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,118 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
