Help with a 07 Avalanche problems
Hello everyone, I bought a 2007 Chevy avalanche fully loaded ltz 5.3l for a very good deal. This isn't my first Avalanche as I had a 09 LTZ a few years ago I shouldn't have gotten rid of, so I was in need of something bigger to pull my small cargo trailer and such and this came up couldn't resis even with the little issues price was right. So let's get down to it.
It says service park assist. If I start the truck it doesn't say it and I can use the switch on the lower dash to turn it on and off. But as soon as I put it into reverse it says "service park assist" I have read this could be an unallinged sensor or damage sensor. I seen they are $45 for 4 maybe just replace them?
Saying service suspension system. This one comes and goes, lots say to check for air leaks, wires around the shocks and such. Truck seems to right nice,
My key remotes. To unlock the doors I have to use the key in the door and press unlock, but once I do that I can use the remote to lock and unlock the doors. So if I shut off the truck get out of it, I can lock it but when I come back out of the store the remote doesn't work again?! I ordered 2 new remotes for the price as these are pretty well used and beat up, even tried both remotes with new battery's.
Any info on this stuff would be great! Thanks!
Service park assist happens when my tailgate is down or when towing, do you have anything in your receiver that sensors are picking up? If not, probably bad sensor.
Service suspension could be a few things. Bad autoride shocks/compressor; replaced non-oem shocks without resistor; or a lift/level kit thats didnt correct height sensors. If it rides good, may just need resistors for $20 on fleabay. Suncore has options for a complete conversion to conventional shocks for around $250 with resistors, or you can buy oem replacements from amz or arnott for $$$.
The keyfob stuff could be just setting it up in your DIC options menu. Might need to go to dealership to program the new ones. Make sure you are setting up everything with fob 1 and using fob 1. The fobs will store seperate settings for each. Or it could be the rf receiver on truck...
Sent from my SM-T350 using Tapatalk
Thanks for the reply! The tailgate isn't down nor do I have my receiver in, I might just replace all 4 for how cheap they are.
Yeah it rides great! No noises, no bouncing or hard hitting and seems to look good while sitting there. Even hauled a steel 22" car hauler trailer and it didn't sag barley, so I feel the shocks and compressor are good working order. I might go under there to see if there is a leak or wiring rubbing or something. Please tell me more about these resistors in the shocks? If I even did replace them I would like to stay air ride that's why I bought a avalanche over a Silverado. What is this option for $250 what does that replace?
I checked my menu says nothing about keys, so I'm going to wait for my new keys to come in and hopefully program them myself like before. I wouldn't see if being anything with the truck as I can walk far away after getting out and still lock and unlock it without problem, so if that was an antenna problem or something wouldn't be able to use the remote at all.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
