Vibration 40 - 70 mph
hmb2016
Hey guys, I have a 2017 GMC Sierra SLT 4X4 CC 6.2 Max tow with 35,500 miles. Tires are factory 275/55/20 Goodyear LS2. I just recently had my tires rotated during oil change (do this every oil change) and ever since then, I have had a vibration at certain speeds from approximately 40 to 70 mph, but particularly bad at 65 mph. I can best describe the feeling in the steering wheel as when you drive over rumble strips off the side of the interstate. Oddly enough, its almost rhythmic and does it once every other second or so.
I got all 4 tires balanced to see if that would resolve problem. Tire shop said 3 out of 4 tires were out of balance and were rebalanced, but this still has not solved my problem. I know there has been discussion about the tires themselves being the issue, but I have not experienced this issue for the last 35k miles. Any ideas? I'm thinking maybe a steel belt broke on one of the tires?
Also, I am about to go on a 1000 mile round trip over fourth of july weekend and would like some imput if yall think its safe to travel in this truck. Ill be pulling a 16' tandem trailer loaded down with 3 four wheelers.
Thanks for the help in advance.
Factory 20" 275/55/20. If the issue is the tires, do yall know if they are covered under 36k bumper to bumper warranty?
If you will research this topic further back in the forum, you will see that GM has had this problem with the 6.2 with max tow since they first came out with the 8 spd. trans.
There have been many, many posts complaining about these vehicles
I had the same issue with my 2015 and after multiple trips back to the dealer with them dinking around with the tires, changing trans oil and other silly crap, they finally got approval to replace the torque converter. The torque converter corrected the vibration problem (which was really severe), but the 8 speed trans is still the pits. It shifts really rough between 2-3 and 3-4. It searches for gears like it doesn't know where it wants to be. Shame on GM for putting crap like this on the road and not fixing their problems. Next time do like I'm going to, get a Ford or a Ram. They seem to try to correct their problems before they put them on the market.
Yeah, this makes sense as I have had nothing but trouble with my 8 speed. Severe clunking at low speeds to the point where I have had to check in my rear view mirror on occasion to make sure I didn't get rear ended. It constantly hunts for gears and 1-2, 2-3 and 3-4 are really clunky and rough shifts.
Already brought my truck to two different dealers 3 times and their final verdict was for me "To drive it until it blows up" as that would be the only way they would replace/ fix it. Certainly not what I wanted to hear after purchasing a truck with a sticker price of 59k. Called GM on this and they said there was nothing they can do. My next purchase will most certainly not be another GM product as a result of this as well as SEVERAL quality issues.
  • 2 years later...
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
