Hey guys anyone having a cluster problem with a battery light?
Hey guys i have a 99 sierra rcsb 4.8/60e im having a cluster problem its intermittent only happens sometimes when i hit a bump in the road and sometimes just idling in traffic, the battery warning comes on, fuel, volt, temp, rpm, speedo and odometer go off. PRNDL stays on, I checked some frame grounds under hood and by the driver side of cab also pulled cluster and checked for broken solders, any ideas on this?
Most likely a Bad cluster the solder joints are on the back of the cluster. Git U a rebuilt one or send yours in for repair. Probably under 100 bones and not that hard to swap out.
