2004 silverado ss p0366 code
Coalkracker
The other day my truck started running really rough and had reduced mpg for about 10 minutes then went back to normal. It was following a day of heavy rain so I though something may have gotten wet. The next day my truck started running very rough again with backfires and sputtering and eventually died and had to get towed. I'm getting a p0366 code for the crank sensor. It starts and runs great until it warms up then sputters a bunch then stalls. Changed the crank sensor today and doing the same thing. Checked the wired and connections and everything seems fine.
It may be the camshaft sensor that's giving you the code they work off each other.
Sent from my Z981 using Tapatalk
