FS: 4.10 Yukon gears for GM 8.5
NIB Yukon gears for a 4x4 truck.
Kit includes the front and rear gears, install kit, TruTrac diff lock, AND a MagHytec rear diff reservoir cover.
$1,100 for EVERYTHING
This entire kit is close to $2000 retail
Located in the New Orleans area
I can ship, but it wont be cheap as these items are heavy but if you're willing to pay for it, I'm willing to ship it.
Paypal only
What year is this for? Call me a noob but what do these gears accomplish? I believe they are used in max tow packages correct?
not really for a certain year, they are for those with the 8.5 axles. However, I know for a fact they will fit GMT900s (08-2013) since that's what I had
ETA: As the other poster said they allow you to run bigger wheels/tires without your transmission hating you, but they will also allow you to tow easier as well. So if you tow a lot these would help with wear and tear/efficiency.
I have that same setup in my AVY. Great parts, sweet deal!b923c1d45d5e44a65860df222f733b48.jpg
Sent from my SM-G930V using Tapatalk
The also fit 2014 Silverados with the v6 incase someone is interested. Those trucks have the 8.5-8.6 differential.
2014 Silverado 2WT 4.3 V6
Instagram @egroj_legnar
YouTube.com/jorge_dropkick_rangel
    • I would argue that GMPartsDirect has that info wrong.    The service manual for R+R the lower arm and for adjusting camber/caster, none of the steps say to discard and replace the nut or the bolt.    The only part that gets discarded is the plastic cam adjustment retainer that is in the eccentric from the factory.     The LCA nut torque spec is:  First Pass: 180 Y (133 lb ft) Final Pass: 90 –105 Degrees   That is WELL past 130ft.lbs per the TSB that you reference that does not apply to this scenario.     As for your clunk.  I'd say it needs to be diagnosed thoroughly.  Assuming the LCA hardware is tight, you could have a problem with the UCA, sway bar end links, etc.
    • The filtering to wear relationship goes like this:      'Relative Engine Life "Factor" new divided by the factor old. So 8/3= 2.67. That result is the multiplier thus if a motor had an effective life of 100K using a filter with a 45 micron rating at a Beta ratio of 75 then a filter with a micron rating of 10 at a Beta of 75 would improve expected engine life to 267,000 miles.    Wear metals are an indirect indicator. Less is better and the motor lives longer but there isn't a multiplier like there is for filtration so well documented. Most of that has to do with the sensitivity of the wear metals tests themselves. They read a 'slice' of the spectrum but not the absolute values for the entire spectrum. So a general indicator that is used WITH the results of other tests. Two others considered in this post. Trending is very important.    There is also the influence of corrosive wear which may be seen in the wear metals but separate from load based or viscosity mitigated indication. It's a small graph but the gray line is wear vs the TBN/TAN crossover. Not as useful as it used to be as there are now new chemistries for acid remediation that don't show up in standard UAO testing. They will catch up or be found liars. Only two possible outcomes, eh?
    • One thing that comes up over and over is that the torque converters are the weak link. Many of the failed transmissions have the same thing in common. The torque converter grenades and then metal torque converter shards end up destroying the transmission. One of the best things you can do is if your transmission is still fully functional, change out to one of the aftermarket billet torque converters. There are several good choices mentioned in different threads here to make your choice. After that, then you can decide about trans tuning. My trans failed at around 95,000 miles. It got replaced under the GM protection plan. The remanufactured trans comes with a 100,000 mile /3 year warranty. I still have just under 1 year left. So far, so good. As long as it's still working good next year, an aftermarket torque converter is going to get installed early spring. If the trans and OEM torque converter fail by then, I will get it replaced under warranty and immediately have an aftermarket torque converter installed. A warranty replacement trans of a replacement trans will no longer have the warranty so I will bulletproof it from the get go.
    • You got'a be cooking right now. Just looked at the weather map. Yuck!    We are right back to $4 today.
    • Pushing $4.00 a gallon in most places, still $3.75 in town but it's going to spike tomorrow for sure.   Diesel back up to $4.60-5.00.
