Always check steering joints before changing the steering box.  Idler arms would fail before a box.  This was my problem.
Any updates to this? I have a 2016 Duramax 4x4 with 40k miles. The last 1000 miles it’s got the death wobble if you hit a small bump around 40mph or so. It tracks completely straight at high speed. It’s had an alignment  and  I checked all the front end parts and everything is tight other that the steering box. The dealer said it’s on me to fix since I’m outside 3/36 I’m pretty irritated that this happened so early. I have a 2.5” rough country and running 33s I’ve had them for 2+ years no issues till now. It also has 2-3” of slop in the steering wheel. Thanks.
Edited by Per_Haugland
Added info
  • 5 months later...
I’m having same issues with my 2016 Sierra Denali with duramax. At 7k miles developed lots of slop in the steering wheel, took it back to the dealership and had the problem “solved” under warranty. Since then I have installed a 5” zone lift and 35x12.5 tires with -25 offset. Truck drove great for about 7 months and started to notice the slop back in the steering wheel. Just took it back to the dealer and said I was out of warranty with 21,650mi on it and said that the larger wheels are what did it and will cost me $1800 parts and labor for new steering box and pitman arm. I refuse to believe that a he can’t handle larger tires. And I have zero desire to spend $1800 just to get it back to stock and potentially have this issue again in a few thousand miles. Anyone have a viable upgrade solution to this issue?
  • 3 months later...
The wobble your having is your brake rotors. All makes of heavy duty trucks have the same issue after getting on the brakes hard for an animal crossing the road or holding the brakes to long with a load on, basically overheating. I put a set of slotted and drilled rotors and matching brakes in the front and it all went away and never came back. Some people do all 4 but I’ve had two trucks that I only did the front and they’ve been fine. When it comes to the steering being stiff, I’ve had it on both trucks. Boys at the shop looked at it and said everything is more than tight, but the lube shop missed a couple grease nipples and that helped a lot for about 15k. If I wash the whole underside of the front steering components and brakes, it also goes away for awhile. Can’t pin point that issue just yet
So as the very first post asked repeatedly;has anyone found the actual solution (or the cause at least)?NV8 RPO appears to be problematic box code(whatever vehicle/colour/trim)TSBs issued and fix appears to band aid a problem.Where did the “play” come from other than wear.Adjust out the slack does not account for the new “space/play” that was created over time.(I assume metal filings in pump/hydro boost system after endplay adjustment made.Partial flush from box removal/replacement.Suspect the GM replacement boxes also have the same basic issues.NOBODY seems to actually know root cause(ie:gear hardness/metal deficiency/fluid inadequacies/pressure or flow problem/contamination from manufacturing processes.Endless forum guesses but zero facts or fixes and alternatives put forward.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
