Maxliner floormat
chris-i
Anyone have maxliner floormats in there truck? Are they good/bad/terrible?
Sent from my SM-G903W using Tapatalk
I had them in my wife's equinox, that are OK fit is good but they do show wear and tear more easily than the WT and husky liners.
If you don't care about them getting a bunch of scuffs from shoes, you can usually find them on sale at autoanything.com
I recently got a rear one for my wifes corolla. Perfect fit and very durable
I was highly considering getting the husky liners but theses look like a good option as well... If you do get them let me know how well they fit.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
