Alighnment
4itodd
Hello I Just lowered my 17 Silverado with a belltech kit 3/5, I had it it aligned and its adjusted all the way and is still off a little does someone make a kit to get it perfectly aligned? Thanks !
Which angle are you off? Camber, toe, caster, right, isosceles?
Belltech makes a camber kit that gets you an extra degree of adjustment. It comes with new plates and requires some grinding of the slots that the upper control arm bolts slide in. You will have the same issue I did since you have a 17. Up until 2016 they used a D-shaped bolt for adjustment. The 17s went to bolts with 2 grooves slotted in them. So you'll have to order the bolts for a 16. You need 4 but they are less than 3 bucks a bolt and the plates are around 25 for the kit from Belltech.
