LMAO
The SPEEDY
I just have one question.....Whats a "Camero"??
I mean, I know what a Camaro is. But I have never heard of a Camero. :)
:) Funny stuff, thanks :eek:
I mean, I know what a Camaro is. But I have never heard of a Camero. :thumbs:
:thumbs: Funny stuff, thanks :sigh:
The best part is that I got that off a camaro web site. He must not see the word camaro on the back of the car or on his dash.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
