Transmission/Electrical?
Zeke6142
2016 Chevy Silverado. I got into my truck last Thursday. Enters limp mode upon startup. Take it to the dealership, they got a code for the transmission. Call me back the next day saying that it's the wiring to the transmission not the trans itself. 48k on the truck and they say it's not covered under the powertrain warranty because it's electrical. Furious about it but agree to pay the 400$. Pick the truck up, service advisor tells me he knows this isn't the solution. Says I'll be back with more issues. Jump in the truck the next day. Battery is completely dead. Can't even be jumped. Tow it back to the dealer...next day they call me to authorize 500$ worth of charges for a new battery and diagnosis. They have no idea what the issue is. GM Corporate says they will do nothing. I need to pay for everything. Only other thing of note is I had issues with the 4WD at 1300 miles. Took them 3 times to fix it. Solution was to replace the solenoid.
Any my suggestions on the next steps?  Feel like I'm getting robbed.
I would be asking what the service advisor meant by this is not the fix. If you have bumper to bumper warranty than it should be covered. Then to demand $500.00 for work they don’t know what is going on, nope they would be fixing your truck. Hope it helps you. Be safe
He should go to a different Dealer.
Dealer Tech should have software to use on his truck to diagnose the BUS and know exactly what is wrong.
Doesnt sound like his Dealer employs an actual mechanic.
unfortunately if the battery is dead then they cannot do any diagnostics so get it back home and do the battery yourself or pay the 500 bucks i know it sucks but you dont have many option with this
Bumper to bumper expired 4K ago. Taking to a new dealership today. Just seems like it should be covered or at least the dealership should fix what they caused.
Ill never but a GM product again. The worst decision I made in recent history.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 451 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
