New 2500HD CC
Well I got a good surprise this afternoon when I went to go get my new metallic grey 2500HD CC 4x4 LT, on top of the $3500 in rebates today GM started offering a "Loyalty" rebate of an additional $1000 so I got $4500 off! Not bad since I was getting it at GMS already. Ended up getting $9337 off of MSRP. Putting 285 BFG ATs on in the morning. :thumbs:
Congrats on the new truck! Always nice to show up to pick up your truck and hear "we're taking the price down some more for you!" :thumbs::thumbs:
BTW- love that color! :D
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
