P0420 code on 2002 Taho
Most likely a converter. They sell bolt on converter Y pipes for your truck at most auto parts stores. I normally get mine from advanced because they give me a discount lol.
They have a set on Amazon for 350 with free 2 day shipping if you're a prime member http://amzn.to/2AcIwrB or 225 with free regular shipping http://amzn.to/2xSeF6e. Comes with gaskets and all. A few more days won't kill the truck.
I would definitely soak my bolts and nuts down with penetrating fluid before I started though. On a 2002 i'm sure they are in need of it.
Hope this helps.
Have the converters checked before replacing them. It still could be O2 sensor issue
