needsome advice
I have a 2007 chevy Silverado 2500hd 4x4 my abs and my emergency brake light are on and then I have no air/heat in my truck. but when they are off I have air/heat but if I try turn the heat/air up or down I get the abs/brake light on and a message service brake system which I just had done. any Ideas. thanks craig
I would like to be more help, but I've never even heard of a such thing like this happening. Seems very strange the the HVAC unit would have any correlation with the abs. Normally when the brake and abs light comes on it's normally a bad hub or some other and issue. Try removing the main abs fuse and see if the hvac is working normally.
One thing that common fails for the ABS system is the ground connector for it, which is one of the wires bolted to the little "wing" off the frame right under the drivers door.  Unblock the wires, clean off the frame and the connectors, put on a bit of dielectric grease, and then bolt it back down.  Note, this applies to your truck if it's a "classic" '07 (GMT-800) and may not if it's the newer GMT-900 style.
As for the HVAC, you might get a pointer as to where the problem is by reading codes from the HVAC computer, but you need a more advanced code reader than a basic one, something like a tech ii or Autogenuity with GM Enhancement.
My 2004 did this a couple times.  First time it was the ignition switch, located under the steering column.  Pretty simple fix, just google ignition switch replacment.  The second time mine did it several months later and it was the pigtail going to that ignition switch.  I can't remember what color the wire was but i could wiggle it and got the lights to go off and air to work. But definately check that area.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
