Highway speed whining
2017 silverado 5.3 with 3.42 rear end. Noticed when its cold out a get a rythmic type whining that comes and goes about every 5 seconds. At highway speeds it more consistent. If i hear it and put it in 4wd Auto it immediately goes away and doesnt return after i go back to 2wd.  It doesn’t do it if its above 45 degrees outside or i drive the truck for a distance. I’m trying to get as much info as i can before i take it in because the truck has aggressive tires and i know i’m going to get the classic “its your tires” response from the dealership. Any info is greatly appreciated
Does it go away with any positive or negative throttle?  Just noise at steady cruise?  If so it's probably your rear differential.  I went through 4 of them in my '15 before they finally got it right.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
