Truck forgot how to Bluetooth?
papageoff
It's been nice weather lately, so the truck's been parked in favor of the convertible.  Last time I drove it was Saturday night and everything was fine.  Today, when I started the truck the phone icon and all the bluetooth options were all grayed out.  I couldn't do anything with it.  I checked the phone and it said was connected.  I deleted the relationship from the phone and tried to re-pair but couldn't.  Restarted the truck, no change.  Finally, I disconnected the battery for a few seconds, reconnected it, started the truck and after about 10 seconds or so everything was normal again.
Anyone else had this happen?  If so, do we know what causes it?
Thanks.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
